Watts link to Panhard Rod
DiscoSlice
- Learner Driver
Anyone out there with experience of any kind relating to swapping out my watts link for a panhard rod. My second set of watts bushings have failed and I’m keen to find a better solution. I’m not against the bent & twisted Lucky8 or RTE link arms. But welding on a panhard rod does seem to be cheaper.
Tony4921
Re: Watts link to Panhard Rod
What make bushings are you fitting? Doing some extreme wheeling?
DiscoSlice
- Learner Driver
I couldn’t tell you the brand of either of the two sets of bushings I installed. And I certainly wouldn’t say extreme.
You probably just need decent quality bushings. Unless you are running a lot more travel than stock, the bushing should last a very long time.
