Defender door tops
troy
Maxi Drive
Defender door tops
#1 Post by troy » Fri Feb 21, 2020 9:13 am
Hello hoping someone can help me out , I have defender doortops for the 88 iam building , they are the one piece aluminum ones with the slanted glass . The glass was glued onto the slides and falling off etc etc . I stripped them and cleaned all the glass ordered all new rubber pieces and those garrison window rubbers for them . The frames are painted and iam ready to put the glass back in the slides , I did take some pictures before I pulled them apart but obviously not enough . Hoping someone with the same door tops can take some pics for me on which slide goes to which glass and where the glass is situated in the slide , and then the seal holder on the rear glass pane . I have a parts breakdown from a rover defender manual but what they are showing for slide to glass orientation to what I have for pictures is different . Anyway help would be totally appreciated . You can email if it's easier [email protected] thank you.
