Hello,
I'm looking for the bleed valse, specifically the plastic screw that goes into the "T intersection". If you're around Victoria that would be ideal!
Thank you! :D
2004 Disco 2 4.6 V8
04 Disco 2 coolant bleed valve
I would suggest getting this to avoid future issues.
https://www.sportscarcentre.ca/aluminiu ... -s?mid=948
SirStackabrick
- Rookie
Re: 04 Disco 2 coolant bleed valve
I have one ordered. I just need an interim fix.red90 wrote: Fri Mar 27, 2020 5:54 pm I would suggest getting this to avoid future issues.
rgallant
BMW uses the same screw, I went to a wrecker and grabbed a bunch. I can send you one via post if it helps
