Range Rover Weather Band Frequencies
RRC Radio Weather Band......
#1 Post by ANDYD » Wed Jan 25, 2006 8:25 pm
Hi James,
The manual lists the Weather Band frequency Range as 162.400 to 162.550MHz.
It goes on to say,
"when the WB button is pressed, regardless of what source you are currently listening to, weather band seek tuning begins automatically & finds the strongest broadcast frequency. If the broadcast frequency in your area is too weak, or non-existant, a beep will sound after the WB frequencies have been run through three times. If you press the WB button again, the radio returns to the previous source."
Hope this helps,
