1960 series 2 cooling questions
pjtrover
Grease Monkey
#1 Post by pjtrover » Mon Jan 18, 2021 9:20 pm
Hello,
I was wondering if a 2a radiator will fit in a series 2 ? And is there a way to get away from the bellows type of thermostat, does the 2a thermostat tower fit a series 2 head ?
Thanks, Paul
PS great site and I'm a new member from down south on Whidbey Island
Cylinder bore
Re: 1960 series 2 cooling questions
#2 Post by John » Tue Jan 19, 2021 8:31 am
The radiator will fit but you need to use the fan shroud from the S2. The screw holes for the shroud may be different. I don't recall the specifics on the thermostat housing. I do have a used thermostat that I could test if you are in need.
Greasy Fingers
#3 Post by Rob » Tue Jan 19, 2021 9:42 am
There are a few differences between the series 2 2.25 engine and the series 2a including the thermostat system. Here is a really well-done article on switching a series 2a thermostat onto an earlier series 2 engine https://1960landroverrestoration.blogsp ... using.html
Hopefully this helps, regards, Rob
pjtrover
Grease Monkey
#4 Post by pjtrover » Tue Jan 19, 2021 3:02 pm
Thanks so much for the helpful answers. That article is great.
New 2a radiators are relatively cheap, so I may get one of those.
Now I need to see if anyone has an extra 2a thermostat tower they'd like to sell.
Thanks Again, Paul
Maxi Drive
#5 Post by harv » Wed Jan 20, 2021 8:06 pm
I was warned about the cheap radiators bursting after a few years so I had mine recored at a local radiator shop. It was twice the price but i have a lot more confidence in it.
