Swivel balls welded to diff case.
dixono
- Swivel Ball
Hello all. I have a high capacity series 3 109 pickup.
The swivel balls are quite heavily welded to the diff/axel casing or better know as the banjo. Any idea why this would be? I think I’ll just use a flap disc on the grinder until the swivels are free. But maybe I need a whole new banjo case? Very weird I must say
dixono
- Swivel Ball
Re: Swivel balls welded to diff case.
Sorry for the 3 posts.
dixono
- Swivel Ball
I was trying to add photos and pressed button to many times
- (27.07 KiB) Downloaded 147 times
- (32.34 KiB) Downloaded 147 times
Pretty sure that is not stock, maybe someone did it to stop the leaking?
dixono
- Swivel Ball
Definatley not stock. It is just welded on the bottom so maybe to stop a leak. It would have been pretty easy to throw some gasket maker in there tho! Not to mention not a common place for a leak. I hope the weld isn’t to deep so I can grind it off and still have a usable casing.
InterMechanico
radio_05
- Gently Used Condition
That looks pretty brutal, good luck fixing that. Might have been a Toyota shop that did that. On the Landcruisers, the swivels are part of the axle, which is a worse design from a maintenance standpoint.
