Coolant question
JBirc0014
- Newbie
Coolant question
Hi all,
Just wondering what to make of this 'substance" I've found in the coolant resevoir and wondering if I can address by flushing system or do you think it requires further (professional) investigation...
JBirc0014
- Newbie
Re: upload issue
Hopefully these post
JBirc0014
- Newbie
Re: Coolant question
Finally got the attachment tab to work...I think
- (234.75 KiB) Downloaded 165 times
- (285.66 KiB) Downloaded 164 times
- (200.02 KiB) Downloaded 165 times
Do you know what colour of coolant it had? What vehicle and engine?
JBirc0014
- Newbie
No idea on original colour. Its a 97 defender 90 300tdi
Unless something else seems wrong like there is gas bubbling out of the tank when the engine is running, I would run coolant flush and then drain and refill. Note that there is a drain for the engine on the left side.
rgallant
I am with Red90 flush and refill, coolant has a lifetime. If you go that route you know you have good coolant.
Actually, it looks like you likely have a “long life organic” coolant. Check out this info link:
https://www.courant.com/sdut-coolant-co ... story.html
My old plastic coolant tank had those same frayed bits of plastic on the internal seam, so that's likely normal.
There is an Orange colour coolant/anti-freeze that turns darker like that. Like mentioned above, I would drain it, give it a good flush through and see how the new coolant looks after a few weeks.
JBirc0014
- Newbie
Appreciate the feedback and info. I will drain and refill this weekend. Had not considered the inner seam, on closer inspect this looks like it could be the culprit.
InterMechanico
Looks like healthy ELC coolant, Cat EC-1 Spec.
Seekerbeta
- Beyond Recovery
now you tell me! after I made countless environmental disasters in my driveway!red90 wrote: Wed Mar 17, 2021 5:12 am Unless something else seems wrong like there is gas bubbling out of the tank when the engine is running, I would run coolant flush and then drain and refill. Note that there is a drain for the engine on the left side.
JBirc0014
- Newbie
This guy seems to have figured out a workaround to the unfortunate placement of spill out to cross member.
