Hello there,
New to the forum, I'm in search of a few parts for my 2004 discovery 2:
-Shocks (Good or uprated standard ride height)
-Steering damper
-Exhaust manifold gaskets and studs
-Rear passenger bumper light lens clear
-Steel front bumper
-Power steering pump line seals
-Roof cross bars to suit 3" 04 disc roof rack or a full roof rack
-Drivers door card panel (felt panel section black)
-Headliner material
-Gear/cdl gators (looking for new)
Based in Nanaimo.
Thanks!
Duncan
Discovery 2 parts wanted
rgallant
Re: Discovery 2 parts wanted
Wish you luck on the list, for the exhaust parts, shocks, steering damper buy new do not mess about with used. Try Bearmach in the UK, it will likely be cheaper than the US and be on your doorstep in 5 days or so.
There is a guy on Facebook Marketplace breaking down some Disco's down in Vancouver but he is a bit pricey
If you are going steel front bumper & Winch you want to consider upgraded springs and shocks. The added weight will change your handling and ride.
Also research the bumpers some are not that great
pragsy
Hi, not sure if you are still looking but I have:
transfer case with CDL (1999)
shocks
stearing dampner
You are probably better to pull the headliner material and just paint it. Thats what I did, works excellent. I have a parts truck in Courtenay. Take the whole thing away if you want. I'm, looking to get rid if it. might have some other stuff of interest as well.
shocks
stearing dampner
