Series 2a clutch
philchan1974
Over Inflated
Series 2a clutch
#1 Post by philchan1974 » Thu Jun 10, 2021 8:53 pm
I will need to replace the boot around the rod that engages the clutch (not sure what it’s called). But I can tell it’s been messed with previously with the original pin removed and a bolt put in its place.
Questions:
1) should I replace this with something more original and, uh, proper? If yes, what should it be?
2) the adjustable fork that connects to this is rusted and the bolts are stuck in place. Should I replace this? And if so what should the adjustment be?
//uploads.tapatalk-cdn.com/202106 ... 62bd29.jpg
Re: Series 2a clutch
#2 Post by mepham55 » Thu Jun 10, 2021 10:27 pm
1. Yes you should replace those bolts with the proper sized clevis pins and you can get a new rubber seal for the gearbox but it’s a Royal pain to install.
2. I think your taking about the clutch slave cylinder push rod so yes you will need to free up those nuts so you can set the free play according to the manual, you have a manual right?!
Maxi Drive
#3 Post by harv » Fri Jun 11, 2021 10:42 am
My experience with replacing rubber boots with “original” (probably meaning Britpart), is that in a couple of years the new boot is worse than the 60 year old one I removed. If you could find something less original it may just last longer.
philchan1974
Over Inflated
#4 Post by philchan1974 » Fri Jun 11, 2021 6:16 pm
mepham55 wrote:1. Yes you should replace those bolts with the proper sized clevis pins and you can get a new rubber seal for the gearbox but it’s a Royal pain to install.
I do. Well the one I have only has the caliper measurement to the nut. This is the one, right?
I’ll order a new clevis pin. I may just order an new push rod too. Afraid the bolts may just be well rusted to be any good.
philchan1974
Over Inflated
#5 Post by philchan1974 » Fri Jun 11, 2021 6:17 pm
harv wrote:My experience with replacing rubber boots with “original” (probably meaning Britpart), is that in a couple of years the new boot is worse than the 60 year old one I removed. If you could find something less original it may just last longer.
Need a “ NOS” supplier :)
jpclinging
Little Wheel
#6 Post by jpclinging » Sun Jun 13, 2021 10:17 am
philchan1974 wrote: Fri Jun 11, 2021 6:17 pm
Have you tried Ike at Pangolin4x4 in Oregon?
Maxi Drive
#7 Post by harv » Sun Jun 13, 2021 9:29 pm
Thanks Kevin. I’ve never used them before.
