Looking for Series Gearbox and T-case Gears - FOUND - No Longer Looking
jacobko
- Crank Case
I am looking for the following gears for a late Series I or early Series II (Suffix A) gearbox and T-case. I have a lead on the intermediate gear, but I need to check to see if it is useable first. I'll be making an order from the UK in two weeks if I can't find anything local. Located in the Kootenays, so would need to be mailed if you're located far away. Thanks! Also, check out Red&Red in the projects section of the forum to keep up to date on the gearbox rebuild!
Gearbox:
- First gear on mainshaft
- Reverse idler
- Second gear matched pair
- Synchro unit
Transfer Case:
- High output gear
- Low output gear
- Intermediate gear
Gearbox:
- Reverse idler
- Synchro unit
Transfer Case:
- High output gear
- Low output gear
- Intermediate gear
Tony4921
Re: Looking for Series Gearbox and T-case Gears
I have several late S1 boxes.
jacobko
- Crank Case
Thanks Tony. I am just looking for the gears, but if you want to take yours apart and see if the gears are any good then I would be interested in them. The last Series I box I bought didn't have good gears, and I don't want to take my chances again.
Tony4921
Sure, I think I have one stripped already. Do you have the gear part numbers or other info?
jacobko
- Crank Case
Tony4921 wrote: Fri Oct 07, 2022 3:45 pm Sure, I think I have one stripped already. Do you have the gear part numbers or other info?
Yup, here are the part numbers:
Gearbox:
- First gear on mainshaft 501617
- Reverse idler 90217389 (old part number 217389)
- Second gear matched pair 245766
- Synchro unit FRC1758 (old part number 239160)
Transfer Case:
- High output gear 218243
- Low output gear 235438
- Intermediate gear 219468
Tony4921
I do have all of those parts, all look in good condition.
jacobko
- Crank Case
Okay I’ve sent you a private message.
jacobko
- Crank Case
Re: Looking for Series Gearbox and T-case Gears - FOUND - No Longer Looking
jacobko wrote: Fri Oct 07, 2022 9:36 am I am looking for the following gears for a late Series I or early Series II (Suffix A) gearbox and T-case. I have a lead on the intermediate gear, but I need to check to see if it is useable first. I'll be making an order from the UK in two weeks if I can't find anything local. Located in the Kootenays, so would need to be mailed if you're located far away. Thanks! Also, check out Red&Red in the projects section of the forum to keep up to date on the gearbox rebuild!
Gearbox:
- Reverse idler
- Synchro unit
Transfer Case:
- High output gear
- Low output gear
- Intermediate gear
