Wanted- steering relay ( fits in frame)
Herman maire
Newbie
#1 Post by Herman maire » Fri Dec 02, 2022 9:36 am
Hello
Looking for 2 good usable steering relays before buying new, this is for 2a project we are trying to get back on the road.
Send me a message with price and details.
Thank you
Maxi Drive
Re: Wanted- steering relay ( fits in frame)
#2 Post by harv » Fri Dec 02, 2022 11:30 am
Hi Herman. I wish you luck (I’m not trying to be funny). As you must be aware by this point, it’s almost impossible to remove a steering relay from an old frame. When I removed mine many years ago, Allen Simpson suggested dynamite (he was trying to be funny…I think).
#3 Post by mepham55 » Fri Dec 02, 2022 6:20 pm
I have a couple used ones here in Victoria. I’ll dig them out and check them over.
Herman maire
Newbie
#4 Post by Herman maire » Sun Dec 04, 2022 8:53 am
Hello, thanks for the replies. It’s unfortunate how difficult these relays are to remove from the chassis, if only they used some form of anti-seize before fitting these relays when new.
Thank you Matt for looking through your spare parts, let me know what you find. I just figured I would check to see what was available before buying new. Let me know the condition and work needed.
I haven’t looked to see if individual parts are available for repairing a relay. I damaged the large brass/copper washer at the bottom of the relay, it cracked on one of them .
On the second relay the bottom of the relay casting body cracked trying to remove it .
StuartC
Wing Nut
#5 Post by StuartC » Sun Dec 04, 2022 12:40 pm
Hello Herman
I rebuilt my relay with parts from John Craddock's......new spring, seals, phenolic tapered bushes (2 sets), and not expensive.
Followed the Land Rover shop manual guide with no problems.....step by step.
Word of caution.......the internal spring when "LOADED" (in the housing) is like python ready to strike!
Your success will be determined by the load applied to move the relay when complete.....12lbs on a spring scale if memory serves.
Stuart
Maxi Drive
#6 Post by harv » Mon Dec 05, 2022 9:06 am
Yes, please heed the spring warning. When I did mine 25ish years ago, I was oblivious to the spring and was lucky I didn’t kill myself.
