Rear drivshaft
troy
Rear drivshaft
Looking for a rear driveshaft for a 4cyl 109 with a Salisbury in the back . Thanks Troy
oldgravy
- Captain Crunch
Re: Rear drivshaft
I believe that the part number is the same as a standard rover diff prop?
troy
Re: Rear drivshaft
No I believe they are different the Salisbury has a longer pinion I believe .
TimberPig
- Bumper Sticker
Re: Rear drivshaft
This is correct. They’re different part numbers, with the Salisbury equipped shaft being 1.25” shorter from online info. Could just have a driveline shop shorten one as well if you can’t find one.troy wrote: Thu Apr 06, 2023 8:49 pm No I believe they are different the Salisbury has a longer pinion I believe .
