So here's a weird one for you.
I've moved from BC to Colorado and I'm trying to get my '85 110 registered. It has been swapped from a 2.5NAD to a 300tdi with a mechanical injection pump and no EGT. The import inspection people have given me two options.
1. install a 2.5 NAD. Not my favourite option.
2. install an electronically controlled fuel pump and egr.
So does anyone happen to have an EDC fuel pump, ECU, harness, throttle pot, and egr bits that they've ripped off their 300tdi? I think my engine has the right fuel injector in number four and a coolant temp sensor. might need a Map sensor or a maf?
EDC fuel pump, egr, wiring harness for a 300tdi
Tony4921
Re: EDC fuel pump, egr, wiring harness for a 300tdi
I have an EDC pump which needs rebuilding, none of the other parts.
