Hi
I have rovacom lite with just the td5 interface as it was the cheapest product that I could find that would do what I needed it to. I found it to be a little gimmicky with poor instructions but it does work.
If you want you can borrow my version but you would need to get the Rangie cables and software.
Ryan
OBDII scanners
landcrabmechanic
Re: OBDII scanners
Hi Ryan,
My td5 has finally arrived. Would I be able to use your rovacom to see if I can get it to remove the immobilizer from the ecu and program the injectors?
Scott
Scott
seatosky
- Half Shaft
Re: OBDII scanners
Just in case this post from 2006 leaves you stranded, I have a NanoCom that just arrived. I don't want to make money from it but it wasn't cheap so I am asking for a donation in return for use!landcrabmechanic wrote: Wed Jan 13, 2021 3:42 pm Hi Ryan,
Scott
