shackle mounting locations?
#1 Post by red90 » Tue May 01, 2007 9:09 am
Do NOT under any circumstances used the U shaped things on the frame. There are trasnportation tie downs only.
Typically people use a hitch in the rear and an aftermarket bumper in the front that has recovery points built in.
#2 Post by DaveB » Tue May 01, 2007 6:09 pm
Go to the wreckers, (A-Combined in Abbotsford, ProTruck in Abbotsford, or Coast Import Parts, Mitchell Island if you can't find one with Rovers up there) and find a Discovery II. It has a nice U-shaped bracket that mounts over top of the bumper, directly onto the frame. The bottom of this bracket is for mounting the stock Land Rover bush bar or A-frame. You can then bolt in Warn or Lordco store brand hooks to these points. I gave mine to Andrew (Nakedbarra) when I put a new bumper on the truck, and they fit on his Range Rover classic, so they would fit no problem on the Disco I. Andrew, got a camera? Post a pic of what we did on yours...
nakedbarra
Mud Pit Boss
#3 Post by nakedbarra » Tue May 01, 2007 6:56 pm
They work a pretty well, We shortend the bolt slot to just the size for the hook bolt holes and the brush bar needed a small trim on the bottom but that will be obvious when you try to fit. The bolt holes for the chassis mount is the same as well.
http://i42.photobucket.com/albums/e321/ ... C03073.jpg
http://i42.photobucket.com/albums/e321/ ... C03072.jpg
good luck
Andrew
