I found the only tricky part in the caliper rebuild was getting the steel seal retainer set without damaging it.
If you have any corrosion in the piston bores, get new calipers
First time I ever tackled it, it took me most of day. That included removing the front rotors and having them turned and repacking the front bearing, new seals, ect.
Regards, Roger
