200tdi electrical
Glenn D.
- Cross Member
200tdi electrical
Anyone know roughly how long my 200 tdi will run with no alternator (belt)?
Is it like 5 minutes or five hours? I want to take the 90 into Rovertech from Downtown.... but I also want to get there :D
I presume it only needs to power the pump slolenoid?
Thanks.
Glenn
Thanks.
Glenn
I can't picture the belt configuration on the 200tdi but if the belt also turns the water pump and you don't have the belt then you will not get more than a few minutes before risking damage. If it is a separate belt then the alternator is not required unless you are running at night and need lights et al.
Glenn D.
- Cross Member
Pretty much forever as long as you don't drain the battery. The solenoid will activate with very low voltage.
In addition, it takes less than a minute to take the plunger out of the solenoid and you can run with no battery, if you like......
FYI, I ran without an alternator for a day this last summer. No problemo.
Glenn D.
- Cross Member
- Landy Man
