Is this the roll bar type that fits on top of the box edge? Single? Double? If so, it should fit with a stock top. Check with Ray Wood at Wise Owl as he just had some made and was showing me the other day.
Defender Roll Bar in my Series3?
Hmmm, did you talk to Ray? Could be a product in development or tied to a hoop set, but I'm sure I saw it there last week.
I assume that you're looking for the roll bar for looks rather than protection? Personally I wouldn't trust one of the miliary bars without reinforcements from the bottom of it to the frame. Better to get a roll bar built that attaches directly to the frame, IMHO...
bclandrover
EX-MOD 90/110 roll bar
I have a good used EX-MOD 90/110 roll bar with bars that angle back and brackets that fit to rear tub for mounting. It will not work with a hard top, requires some mods to fit Series. You can come over a look at it if you want and maybe we can make a deal.
As for Dave's comment re: strength and attaching to the frame...
...Although attaching to the frame is ideal, the 90/110 roll bar attaches to the rear tub with two massive brackets plus the two support bars. I would say it's way better than the series roll bar which has no real support and simply bolts to the galvanized capping. Also, I bet the 90/110 roll bar fitted correctly would do better than a stock hardtop in a serious roll over.
Later,
Don
Later,
Don
