So I am blowing wiper fuses in the 90 like crazy and was wondering were
to start looking for a fix? Wiring (for a short) first
or the motor/or wiperpark switch?
Or something else entirely?
Google was only maginally helpful.
It always send me here!
Glenn D.
Ps are the fuses an odd length? The ones I buy to replace them seem too long
1986 Defender 90 . Wiper fuse blown
Glenn D.
- Cross Member
Wipers...
Hi Glen,
The simplest way to narrow it down is to disconnect both wipers at the motors and switch them on. If the fuse blows then it points to the switch or the wiring.
If it doesn't blow the fuse then reconnect one wiper at a time and see which motor blows the fuse.
If there is no disconnects at the motors you may have to crimp some on.
One other thing to check, are there any other lwires on the wiper fuse apart from the wipers?
It is always a possiblity that someone has added an "accessory" to the wiring at sometime in the past!
Good luck,
Good luck,
Re: Wipers...
Maybe I misunderstand what you are meaning, but there is only one wiper motor.ANDYD wrote:If it doesn't blow the fuse then reconnect one wiper at a time and see which motor blows the fuse.
It could be a wiring problem. It could be a motor problem. It could be a binding problem in the drive system.
wiper fuse blowing
Thanks John,
You are right, I was thinking of my old series....
Still, same idea, just with the one motor,
