Crapped out Salisbury?
tony
So this year on my way home from Moab the engine ran fine but it seems the last of the rover parts are giving out. I pulled the Salisbury diff. cover off to find out what went wrong and found nothing that I could see, yet in Spokane it felt, and I do mean felt like mismatched gears and the noise that it made on the highway in overrun was nothing as tame as a Series trucks. After disconnecting the prop and removing the half shafts and running home in FWD all the noises disappeared. So how can you tell if the Salisbury diff. is shot? and if its not that, then why didn't the T-case continue to make any noise after disconnecting the diff.? unless the load changes without the rear prop being driven by the T-case.
Hi Tony,
You removed the rear drive shaft... In my series truck I had noise very similar to what you describe and discovered after looking at the major components that the problem was actually the slip-yolk on the rear driveshaft. Check very carefully for any play in the driveshaft before digging deeper.
Dave_F
- Washed Up
tony
It cant be the prop shaft as it is a brand new GBR one which got re-balanced in Missoula Montana by Inland Truck Parts and service who I can not say enough good about, very Rover friendly. $147.50 for 3hrs of pissing around and drive shaft balancing, and they took me in with no waiting. 1-406-728-7413 ask for Don.
So what I hear (or want to hear) you guys saying is that it's not the T-case yes? and it could be the Salisbury even though it seems to be tight with no play in the bearings.
Looks like I'm building a case spreader next week in that case.
tony
tony
Are the spiders OK? Maybe you lost a thrust washer? Take the center apart and see what you have to deal with. It would be pretty weird to have damaged the 4 pin Dana 60 center!!! I would guess a washer came out.
Kirk must have a stock center in the garage, no??
You know you want to put in an ARB....
tony
Roverworks
tony
tony
email me at [email protected] and i will send you a picture of whats left of the plug.
