I have a 2001 D2 - it is an SD model but I think it has had a "heated" windshield installed in it as a replacement sometime in the past (has the fine filament wires in it). What do I need to do to power-up the heated shield? The SD doesn't have any controls for the heated windshield that I can find. Any advice would be appreciated.
Regards, Rob
D2 heated windshield question
Heated windsheild
Hi Rob,
At the lower corner of the windsheild (I can't remember left or right side) there will be a couple of wires attached to the glass (or a couple of connectors) probably just out of sight under the interior plastic trim around the glass.
If you dont have any previous wiring or a switch it can be easily added. You will need a fused 20 amp power source running to a relay, then a switch (with a light) wired to operate the relay (fairly simple circuit if you have some electrical knowledge)
Then the only thing missing would be the timer. Most heated windsheilds have a timer in the circuit to shut it off after 5 mins or so. You would have to pick up one of these, maybe from a breaking RRC or Disco or just remember to manually shut it off after a while.
