After alot of hunting around i have finally found the part number for the heater valve for trucks fitted with Kodiak heaters. Thought I'd pass along the part number if anyone needs one.
Four Season #74662
prices range from $30-80 so shop around.
a cheaper alternative is to ditch the old valve and use Chrysler Part 4085564 which is basically the same as the original heater valve but fits inline, so you can shorten your cable and make the heater operation smoother. prices $15(Ebay) $30 local
Kodiak Heater Valve part number
