Trailer wiring plug adapter for north american plugs
davran
#1 Post by davran » Tue Aug 16, 2011 7:41 pm
Is there an adapter to change the trailer wiring plug -- which is tucked behind the right-rear tail light of the D2 -- to the flat, four plug north american type?
#2 Post by DaveB » Tue Aug 16, 2011 8:17 pm
Hi Dave,
I spliced directly into the light harness and added an adapter like this:
http://www.princessauto.com/components/com_virtuemart/shop_image/product/8201881.jpg
The components shown here are from Princess Auto, since they list them all on their website, however your local Lordco and most other jobbers have the same.
Note that the output here is 4 pin flat, which is what you're looking for. However, I found that there are a lot of trailers that use the very common 7 pin RV plug that I have to tow, so I did a bit more...
First I purchased a trailer brake controller. There are lots of these out there, but in mot cases you only need the cheapest, unless you're planning to tow more than 3 axle trailers!
Brake controller example: (mine was similar, but from Lordco)
http://www.princessauto.com/components/com_virtuemart/shop_image/product/8023523.jpg
Seven Pin plug for back of truck:
http://www.princessauto.com/components/com_virtuemart/shop_image/product/8212029.jpg
Finally, to provide 4 pin output when I'm only towing a light utility trailer, this adapter for $7.99 works very well...
http://www.princessauto.com/components/com_virtuemart/shop_image/product/8305534.jpg
Hope that helps.
cheers, Dave
davran
#3 Post by davran » Wed Aug 17, 2011 9:45 am
Excellent, thanks!
