How bad is your clunk?
discojonny
So I have been driving my 110 for a while now and it has the clunk. I have replaced the ujoints and it is better but still there. I tried locking the diff last night and the clunk dissapeared. Any one have any thoughts on what it coud be?
And how much driveline slop are the rest of you experiencing?
Dave_F
- Washed Up
discojonny
Dave_F
- Washed Up
After a run up to the Whipsaw and having my difflock pop out a few times on steep hills, I had the clunk.:oops:
Since I had Don at Rovertech replace all my U-Joints (it was raining and my garage is full of Series 1''s)...the truck is nice and tight.
Put it in Neutral and crawl underneath and twist the driveshafts to see if you have any play...make sure you are on flat ground :shock:
Speaking with Kris and Pete...U-joints are a common item to keep an eye on as they are considered "consumables" :lol: :lol:
Could be splines in the d-shaft...but you should be able to feel the play if so.
Good luck and keep us posted on your progress.
- Landy Man
Hey Jonathan,
Clunks can be frustrating I know, driveline slop or lash is significant with all that machinery rotating and not easy to isolate where there is too much. Her is a list of my clunk history.
The aforementioned u-joints- consumable and really should be assessed with the wheels off the ground.
Drive-shaft splines-mine resulted in more vibration than clunking.
Ball joint on rear axle- mine was a low thud rather than a clunk.
Transfer case input gear - this will clunk worse as it gets more sloppy, eventually stripping the mainshaft output splines $$$$
Tie rod and drag-link ends - I was really surprised how much clunking these can cause but pretty easy to repair.
Front Panhard Rod bushings - sometimes the clunk is from the holes in the brackets becoming oval rather than the bushing.
Axle/hockey stick bushings - difficult to pinpoint which is giving the clunk, mine often showed up under deceleration.
Defender Clunk
Hi Jonathon,
I too have a bit of a "clunk" on my 110, It annoyed me at first but I have learned to ignore it. Just put it down to being a 20 year old truck.
I checked the U-joints and they are all fine.
I also had a "clunk" on my 1967 series truck and a "clunk" my 1991 RRC :roll: so business as usual.......
cheers, Andy
cheers, Andy
discojonny
Dave_F
- Washed Up
