Disco I doors won't lock and interior lights come whenever
chilliwack
#1 Post by chilliwack » Wed Mar 14, 2012 6:23 pm
The doors unlock when you try to lock them and the interior lights come on sometimes when I was driving. Problem starts after a few days of rain
Pulled all the door switches, found 3 of them were damp. When I threw a multimeter on them I found one them 3000K resistance :idea: rather then going open circuit.
Gave them all a good shot of WD40 and covered the exposed strap on the side with some electrical tape.
Retesting found them all going open circuit properly. :)
Reinstalled, everything seems to be working properly now.
I'll update once I know it worked, but looks good now!
Roger
jeepingpw
Worm Gear
#2 Post by jeepingpw » Thu Mar 15, 2012 8:05 pm
In my Disco 1, sometimes while driving, the doors will lock & then the alarm goes off.
I have to pull over & lock/unlock doors multiple times with key to shut alarm off.
I have found that if I lock the drivers door first (locks all doors) , from an open left rear door, the alarm will not arm & problem solved.
Landy Man
#3 Post by Bill E. » Fri Mar 16, 2012 12:19 pm
I find that connecting and disconnecting the seat belts six times in quick succession then getting out and walking to the rear of the vehicle will sometimes work. :roll:
Doc Tari
#4 Post by Doc Tari » Fri Mar 16, 2012 8:08 pm
Mr. Secretary, you're just jealous 'cause you don't have power locks or an alarm...
