attached is a webpic of a series II oil filter assembly. Does anyone know what the bolt in the top right had corner of the photo is for?
hose (capillary) for oil pressure gauge?
Series II Oil filter assembly
TOLON
- (169.16 KiB) Downloaded 1729 times
Re: Series II Oil filter assembly
Yep for running a ,mechanical oil pressure gauge. Is this yours or are you buying one? I have one your can have for free if you need one.
Victoria BC
Victoria BC
TOLON
I'm thinking about getting one as I have the dual water temp/oil pressure gauge....does the hose just screw in or is there some adapter required?
There's a banjo bolt that fits between your oil pressure sender and the housing.
There one one eBay right now
https://touch.ebay.com/tablet/item?item ... 7396&rd=vi
