Are there any resources floating around to help me determine what particular vehicle my Transmission came out of? Or What box numbers were used in what models/years.
I paid only 20 bucks for the transmission and transfer case and it was 'thought' to have come from a disco 1 but how do I know for sure?
The application I'm working with requires one of the boxes where the torque converter flange, when properly seated sits 51mm back from the face of the bellhousing.
The box code for mine is 747 so according to ashcrofts it will sit 27mm. It would seem that I need a transmission with box code 332, 593, 699, 740, 741, 742.
what would be really helpful is to come up with actual vehicle models and years that will suit rather than asking potential sellers to crawl under their trucks and find me the code (to which I have not yet had any response)
ZF4hp22 matching serial number to vehicle model/year?
RamblerRob
- Green Laner
John Boy
Re: ZF4hp22 matching serial number to vehicle model/year?
Those numbers match the transmission I am using in my build, its came from a 1995 Land Rover Discovery... so there is model and year figured out.
- (99.76 KiB) Downloaded 2236 times
RamblerRob
- Green Laner
That is tremendously helpful thank you.
If anyone can tell me a number from any other model years I'd very much appreciate that too.
RamblerRob
- Green Laner
Information gleaned from ZF
I can only tell you the production years of the transmission. I do not know the years which it was installed in the vehicles. They should be similar though.
742 01/92 - 12/93 Discovery 3.5L
741 01/92 - 06/95 Range Rover 3.9L
740 01/92 - 09/02 Range Rover Vogue LSE 4.3L
699 01/89 - 12/92 Range Rover 3.9L
593 01/87 - 12/89 Range Rover 3.5L
332 01/87 - 12/88 Range Rover 3.5L
