So the drain plug is totally hooched on my rear cover... I know that Salisbury axles "are" Dana 60's, but how far does that go? Can I take the rear cover plate from a Dana 60 and replace mine? Also... I need to change all my fluids lol I spent over an hour stuck chest deep in a river...
Yea so my main question before I go drop money on a Dana 60 cover plate is will it fit and are there any differences from year to year etc
Thanks guys
-Vaughn
Dana/Salisbury rear cover plate the same?
Re: Dana/Salisbury rear cover plate the same?
Yes, they are the same. You may or may not need to open the holes a bit as the Dana 60s use 3/8" bolts and the Salisbury uses 10mm. Usually they are okay.
