Smooth running again.
#1 Post by Greg S » Mon Aug 29, 2016 2:57 pm
Over the years I've changed my carburator several times. The best I ever had was a twin SU setup but that got sold on my old 88 back in about 1978. Best I've had since was the original Zenith but it eventually suffered a worn throttle shaft and I tried to fix it, not very successfully. Worst I've had was the single barrel Weber; thought it was great the first few summery months I ran it. My Rochester B was okay, lots of power but stumbled a lot coming off idle, especially on an incline. I finally am back to an SU. A single on the aftermarket intake manifold made for it. It ran smooth as could be except sometimes. H'm! I decided the trouble had to be electrical and when my trusty 2.25 started crossfiring and backfiring and blew out the muffler a couple weeks ago, I was sure of it. I swapped in an old but trusty looking distributor with an old set of points and my same cap, rotor, wires and plugs. After warm-up, surprise surprise, she runs as nice as you could ask for.
Now I have to get my colds start cable to be an inch longer and it might run okay even when cold.
She runs so fine now that I'm starting to feel spoiled.
BlkP38
Bumper Sticker
Re: Smooth running again.
#2 Post by BlkP38 » Mon Aug 29, 2016 9:20 pm
Well done Greg. I have always loved the grace of a well tuned petrol LR gliding across the field. This from an oil-burner!!
Eric.
#3 Post by Greg S » Mon Aug 29, 2016 10:38 pm
If only I had a turbo I wouldn't have to worry about that blown up muffler.
terayon
Swivel Ball
#4 Post by terayon » Wed Sep 28, 2016 8:43 am
Nicely done! I'm looking at switching mine to some sort of petronix ignition. What were your impressions of the Rochester B? I've got an old Solex myself and while it runs smooth I wanted a cheap and easy way to get a few more HP.
Jordan
Sent from my SM-N910W8 using Tapatalk
#5 Post by Greg S » Wed Sep 28, 2016 10:27 pm
The Rochester B worked well with lots of top end but suffered a severe case of bogging at very low speed. Now I find it may have been a worn out distributor. It had a few other issues that I devised work arounds for. Finding different sized jets is a search into old hotrod guys bottom drawers.
