Get a text from my wife today that our 2012 LR4 (50,000 km) is displaying the following message:
"Suspension Fault: Normal Height Only"
Then when driving down the highway the vehicle also started making a loud rumble sound and a vibration she could feel in her seat.
Does anyone have experience with this fault message? Does it point to one particular failure of something or is it a generic message that could mean many things?
Thanks!
LR4 Suspension Fault
HeliRy
- Apprentice
DBrands
- Wing Nut
Re: LR4 Suspension Fault
This might be a stab in the dark, but possibly a compressor issue. I don't own an LR4 so can't say whether a failing compressor could resonate through the body to the driver's seat, but might be a place to start. Try raising and lowering the suspension?
Check over on Disco3.co.uk (They have a dedicated Disco 4 Sub-forum if you're picky!)
vernbLR3
I never had the rumble but that error is indicative of failing compressor. If you have a Hawkeye OBDC reader it will give you more information. Replacement with new OEM it's 2k ish with installation but I recommend OEM.
