BLEEDING...... (not me)
Roverworks
Strange indeed….I suspect that the fluid leaked from the clutch chamber of the reservoir to the brake chamber. If you were to disassemble the reservoir you would find a rubber seal at the the base of the central chamber (clutch). This rubber seal can crack or perish allowing the clutch fluid to drain to the outer (brake) side of the reservoir. Easy to fix if you can get it all apart. Use a neoprene washer to replace the faulty one.
Alan
IP Mechanic
Rover Works B.C. ltd
Alan
IP Mechanic
