Transfer case modification
reefworld1
Hi, Does anyone have any info regarding the high ratio transfer case mod. This is suppose to overdrive only your high range?
Good day:
You might find this site of interest:
http://users.mrbean.net.au/~rover/high. ... l%20Ratios
it has info regarding high speed transfer case conversion for series rovers
Regards, Rob
83 88
88 RRC
Regards, Rob
83 88
88 RRC
reefworld1
transfer case mod.
I checked out this site but it doesn't give enough tech. info to perform the machining.
Ashcroft transmission has a complete kit:
http://www.ashcroft-transmissions.co.uk/part_37.html
Might be your cheapest in the long run.
