Cv Joint
PaulC
Yes, just last week, Rovertracks re-released the 4340 CV, shaft set.
$660 USD for both CVs and halfshafts!!!
http://rovertracks.com/products/axles.html
The CV joints are the same as used by Longfield in the 30 spline Toyota setup (other than the stub geometry). All should be much stronger than the Rover ring and pinion.
It is for the later style axles only, so if you have an early axle, you'll need to swap to the newer hubs and spindles.
