2.25l diesel fuel inertia/cut off switch
andrewMcF
Crank Case
#1 Post by andrewMcF » Sun Jan 30, 2011 12:09 am
I'm trying to resurrect a 2.25 diesel engine that I have and I don't really know too much about diesels... my question is which way is the cut off switch giving fuel to the injectors (on) and which way is off?
Cylinder bore
#2 Post by John » Sun Jan 30, 2011 8:32 am
To shut off the fuel you would pull the control cable thus it needs to be pushed in to operate.
andrewMcF
Crank Case
fuel shutoff
#3 Post by andrewMcF » Tue Feb 01, 2011 3:00 pm
The problem with the pull to turn off and push to turn on is that the engine is out of a vehicle and there is no cable to speak of attached to the shutoff switch, so I need to know what the actual physical position is for on off...
