I'm trying to resurrect a 2.25 diesel engine that I have and I don't really know too much about diesels... my question is which way is the cut off switch giving fuel to the injectors (on) and which way is off?
Andrew
2.25l diesel fuel inertia/cut off switch
andrewMcF
- Crank Case
andrewMcF
- Crank Case
fuel shutoff
The problem with the pull to turn off and push to turn on is that the engine is out of a vehicle and there is no cable to speak of attached to the shutoff switch, so I need to know what the actual physical position is for on off...
Andrew
Andrew
