Sandblasting firm for a bulkhead?
#1 Post by bsa_m21 » Sun Jul 19, 2020 1:14 pm
Does anyone in the lower mainland (BC only) know of a firm that can sandblast clean a bulkhead?
Thanks.
Re: Sandblasting firm for a bulkhead?
#2 Post by bsa_m21 » Wed Jul 22, 2020 3:50 pm
FYI - I found a car resto firm in S Surrey, called Icing on the Car, that let’s you blast large parts yourself in their blasting bay, for a very reasonable hourly rate. Just did my bulkhead and front bumper this morning in 1.5 hrs. You need to supply you own mask/filter, gloves, ear plugs and face shield or blast hood. I wore coveralls and some sand (actually blast media) still got into my private parts. :roll:
Picked up some por15 and Eastwood frame seal at KMS Langley on the way home, so am ready to start prepping the bits for paint. Yay!
jpclinging
Little Wheel
#3 Post by jpclinging » Wed Jul 22, 2020 11:14 pm
You blast it , in Langley. I did my entire truck there.
#4 Post by bsa_m21 » Thu Jul 23, 2020 9:42 am
FYI - U blast was my first call, but was booked up and turned out to be a much higher the hourly rate anyhow. 😲
philchan1974
Over Inflated
#5 Post by philchan1974 » Thu Oct 08, 2020 8:53 pm
Just wondering - blasting the aluminum on the series 2 - any thoughts on doing this right and not allowing the panels to warp? Soda? Walnut? etc?
#6 Post by mepham55 » Fri Oct 09, 2020 4:28 pm
I had everything on my truck blasted before I rebuilt it 10yrs ago. I asked the fellow doing it and he wasn’t worried about the aluminum. He used garnet and just lowered the pressure. Nothing warped. This was a company in Chemanis that does oil rigs and giant things.
RobinS
Over Inflated
#7 Post by RobinS » Sat Oct 17, 2020 6:16 am
What was the company's name in Chemainus Matt? A friend is almost at the paint stripping stage
#8 Post by mepham55 » Sat Oct 17, 2020 1:30 pm
RobinS wrote: Sat Oct 17, 2020 6:16 am What was the company's name in Chemainus Matt? A friend is almost at the paint stripping stage
Sorry Robin, I should have included the name!
https://nanaimofoundry.com/
The fellow I dealt with, appropriately named Garnet, no longer works at the facility. I did call them about 2yrs ago and they seemed to still do blasting.
RobinS
Over Inflated
#9 Post by RobinS » Thu Oct 22, 2020 5:50 am
Thanks Matt
StuartL
Horn Blower
#10 Post by StuartL » Thu Oct 22, 2020 6:15 pm
We used soda blasting on the Grizzly Torque with amazing results.
(39.45 KiB) Downloaded 148 times
(44.09 KiB) Downloaded 148 times
oldgravy
Captain Crunch
#11 Post by oldgravy » Sat Oct 24, 2020 8:21 pm
bsa_m21 wrote: Wed Jul 22, 2020 3:50 pm Picked up some por15 and Eastwood frame seal at KMS Langley on the way home, so am ready to start prepping the bits for paint. Yay!
What prep are you doing on the newly sand lasted parts, Martin? I am guessing you probably don't need to acid etch the metal first since it's pretty bare...
#12 Post by bsa_m21 » Sun Oct 25, 2020 6:32 pm
oldgravy wrote: Sat Oct 24, 2020 8:21 pm
Straight onto the bare metal after a good wash and blow dry. :bounce:
