Hello,
I'm planning to put a fresh clutch in my 1967 109 Six Cylinder that has a Chevy 250 installed with Scotty adapter.
Will a normal Land Rover IIA clutch disc and pressure plate work for this? From what I've gleaned from Google, which might be wrong, the conversion uses a Vega (!) flywheel which matches up to the Land Rover pressure plate bolts. I'd like to get the right parts before I take the truck apart.
Paul in Victoria
Clutch question 67 IIA 109 with six cylinder Chevy Conversion
pquin
- Gently Used Condition
TimberPig
- Bumper Sticker
Re: Clutch question 67 IIA 109 with six cylinder Chevy Conversion
If it is still using the Land Rover gearbox, the normal combination is a Vega flywheel with a 9 1/2” Rover clutch from the late 2a with the appropriate pilot bushing to fit the combination. Your setup could be different depending on what has been done with your truck’s conversion.
pquin
