Went for fully-galvanised doors from SP-4x4 in Liverpool.
Looking for recommendation for a paint shop in the lower mainland to take the loose doors to for painting, before I build them up.
Finally bit the bullet and ordered 4 new doors....
withabix
landcrabmechanic
Re: Finally bit the bullet and ordered 4 new doors....
I use Vancity Autobody on kingsway for most of my painting needs.
withabix
Doors were dispatched on Friday and arrived on Tuesday!
To give you some idea of how bad one of my doors was, take a look at this…
Once I’ve finished, I will be posting the door carcasses for refurbishment. They require various levels of refurbishment, ranging from the front right which has evidently been previously refurbished and is reusable as it is, to that right 2nd row above, which might yield some material…
I’m re-using all of the hardware except perished rubber, so they would be completely bare.
bclandrover
HI Iain,
Rovalution has an entire division with Red Seal Autobody and re-finishing technicians, dedicated to accessorizing, upgrading and restoring Land Rovers.
We be happy to discuss the costs to do this work for you.
Please give our Projects Manager, John a call 604-985-6317 Option2
Don
Don
