Tub floor replacement
philchan1974
- Over Inflated
I'm looking to replace the floor on my 2a 88 tub. There has been corrosion due to the supports being replaced with metal - and it has reacted causing a hole.
Any ideas for a better way to do this? I do have a donor tub that I could sacrifice the floor...
philchan1974
- Over Inflated
Re: Tub floor replacement
Understood. But the originals were replaced with square tube non galvanized steel causing a reaction
My question is how best to replace the floor. Not what the supports are…
Hi Phil,
Depending on how bad it is a good welder can patch holes in the aluminum tub floor, but not a cheap option.
Hard to ship but you can buy a replacement part like this - https://www.bits4landys.co.uk/s2_s3_88_ ... 330267.htm
Depending on how original you want to keep it, in the UK I often saw diamond aluminum panels cut to fit inside and just installed right on top of the old floor with rivets.
- (33.33 KiB) Downloaded 68 times
- (277.34 KiB) Downloaded 67 times
You buy the replacement supports from the link I showed and aluminum sheet locally.philchan1974 wrote:Understood. But the originals were replaced with square tube non galvanized steel causing a reaction
RobinS
- Over Inflated
The floor on my tub was corroded also . I cut the bottom out and had a welder weld a new floor in and the ribs also. The corrosion went up the sides in a few spots so he welded in a couple of patches. After paint it's barely noticeable.
RobinS
- Over Inflated
I wanted to add these pictures last time but was having trouble adding photos . I hope they are helpful.
- (119.89 KiB) Downloaded 26 times
- (60.88 KiB) Downloaded 26 times
