Series 2a 109 Four Door- Doors, Rear Tub and etc. Alignment!
Dijan1993
- Swivel Ball
Well as I get closer to the body and assembly to the frame of my 109 2a... Is anyone aware of any videos that are really helpful to the assembly process or of things that they may have done to build their own series truck? I could use any and all helpful information.
cbalme
- Slave Cylinder
Re: Series 2a 109 Four Door- Doors, Rear Tub and etc. Alignment!
There was a video from Brittanica Restorations a few years ago about lining up the doors and bulkheads.
Overall the main point was that the tub does not have any adjustment so you start from the back and work your way to the front. You will need to add spacers depending on the gaps you want.
I found aligning the bulkhead worked best with a ratchet strap from the window hinges to the front frame horn to fine tune it.
Make sure every bolt is loose as well while adjusting the pillars and bulkhead
Dijan1993
- Swivel Ball
Thank you Colin,
I will use your advice, onward and upward!
Dijan1993
- Swivel Ball
Colin, Maybe you know... I would like to find more about my Series and I have the VIN. is there a website or etc. that I can contact to get the breakdown of the series IE date of manufacture and etc or even a build sheet?
cbalme
- Slave Cylinder
TimberPig
- Bumper Sticker
The link I posted in your other thread gives more of this info as well.
Dijan1993
- Swivel Ball
Thanks everyone...Close to driving...
oldgravy
- Captain Crunch
Nice work!Dijan1993 wrote: Mon Jun 16, 2025 9:45 am Thanks everyone...Close to driving...
First roll out of the garage.MOV
