Looking for a front drive shaft. I think the 86” and 107” fronts are the same.
Thanks!
Series 1 front drive shaft 1954-1957
roverdevin
- Junkyard Master
Re: Series 1 front drive shaft 1954-1957
Series 1 driveshaft lengths:
80 (1948-50) Front 521mm / 20.512"
80 (1948-50) Rear 386mm / 15.197”
80 (1950-53) Front 554mm / 21.812"
80 (1950-53) Rear 407mm / 16.024”
86, 88 Front: 604mm / 23.812"
86, 88 Rear: 554mm / 21.812"
107, 109 Front: 604mm / 23.812"
107, 109 Rear: 1087mm / 42.812"
Series 2/3 driveshaft length (non-Salisbury):
88 (4 cyl) Front: 604mm / 23.812"
88 (4 cyl) Rear: 554mm / 21.812"
109 (4 cyl) Front: 604mm / 23.812"
109 (4 cyl) Rear: 1463mm / 57.600"
M.
M.
I’ve got some spare front props. Looks like what Martin has posted shows the 86” is the same as all other Rover front props.
roverdevin
- Junkyard Master
So looks like and series front after 54 should be fine! Does anyone know if there are differences in them beside length? I’ll take anything serviceable. I will be changing the ujoints.
roverdevin
- Junkyard Master
Scratch that. I just found one in the back barn. I guess it’s time to do some inventory.
